Knock sensor?
Old Apr 29, 2003 | 05:54 PM
EK99hatch's Avatar
Default Knock sensor?
I have 2000 gs-r swap in my 95 civic si hatch, and I am still using the sohc vtec wiring harness which leaves the kncok sensor disconnected from the rest of the wiring harness and makes my check engine light come everytime I start the car. What pin # does the knock sensor go into?
Thanks
Scott
Old Apr 29, 2003 | 07:05 PM
VTECVillain's Avatar
Default Re: Knock sensor? (hondavtecsi)
D3 and make sure to use shielded wire.
Old Apr 29, 2003 | 07:15 PM
poison's Avatar
Default Re: Knock sensor? (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">D3 and make sure to use shielded wire.</TD></TR></TABLE>
yep yep.
chris ya ever get me back for the mail?
Old Apr 29, 2003 | 07:38 PM
Default Re: Knock sensor? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">chris ya ever get me back for the mail? </TD></TR></TABLE>
No you aren't important enough!
Old Apr 30, 2003 | 05:45 PM
EK99hatch's Avatar
Thanks for the reply!
Old Apr 30, 2003 | 05:55 PM
EK99hatch's Avatar
What kind of wire is shielded? Can I get it off of my old wiring harness?
Thanks
Scott
Old Apr 30, 2003 | 06:26 PM
EK99hatch's Avatar
How much of a loss in hp am I at with the knock sensor disconnected? Vtec feels good and it goes to 8k?
Thanks
Scott
Old Apr 30, 2003 | 06:35 PM
poison's Avatar
No you aren't important enough! </TD></TR></TABLE>
HA. i see how it is
Old May 5, 2003 | 05:12 AM
HKxBlur's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondavtecsi &raquo;</TD></TR><TR><TD CLASS="quote">What kind of wire is shielded? Can I get it off of my old wiring harness?</TD></TR></TABLE>
Old May 5, 2003 | 08:48 AM
Default Re: Knock sensor? (HKxBlur)
Yes you can salvage shielded wire from both cabin and engine harnesses. They will have a gray jacket and are about 1/8" thick. Inside the gray jacket will be a regular single wire and then a bare braided wire that spirals around it. The bare wire needs to be grounded on either end, usually on the ECU side.
I got a honda
Aug 23, 2008 05:20 PM
integg93
Aug 3, 2006 01:17 PM
xwade01
Mar 17, 2005 09:53 AM
integlspwr2k
Mar 8, 2005 04:45 PM
Phatch99
12
Jul 22, 2004 03:08 PM
