what axles and hubs do i need
im trying to put an LS motor i my friends 89 hatch and the only problem im having is the axles wont fit in the hubs i was told to use 90-93 teg axles correct me if im wrong and the axle will not fit in the hub the axle is to big for the hub so if anyone has done the swap or knows how to do it let me know please thanx
What year is the engine? I would assume you could use any year Integra axles. If the axles really are too big for the hub, ( you might have to use some force to get them in...they might not just 'slide' in ) then use the axles that came with your engine and then use integra hubs as well. Then it should all match up.
Sorry I'm not much help on this. But I think that all the integra and civic axles are interchangable [in the same series], but that year civic is kinda old, so maybe they are different. Does anyone know if the civics were that different before 1990?
Re: what axles and hubs do i need (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">is the hatch a STD? if so, you need different hubs - otherwise 90-93 integra is correct and should fit hubs</TD></TR></TABLE>
Yup, exactly what I was going to say. STD Civic/CRX and the HF have a smaller hub, so you need to swap them out for the CRX DX/Si (or Civic hatchback that's not STD) or any Integra hubs will work, but be sure to use your stock Civic upper A arm (we just did an 89 Civic hatch and put on 95 GSR brakes, using the entire knuckle... fits just fine when you use the stock upper A arm). Instead of pressing out the hubs, just find some knuckles.
Re: what axles and hubs do i need (poison)
yeah axles can be a pain. I spent 20 min pounding on an accord one b4 i got out enough threads to put on the axle bolt and then tighten it. DONT do this if there are like 3 treads sticking out, it will strip the axle bolt. wait till you can get like 8 or 9 good turns on it. Then just start tightin it.
Blaze
Blaze
The STD/HF are significantly smaller and have 2 less splines. You will need 88-91 Civic CRX DX or Si hubs or ones from a 90-93 Integra's (this will allow for a brake upgrade too). If you were staying with a D series and just changing to a DX/Si 5 speed you can reuse the 4 spd axles because the inner CV joint's and splines are the same.
