Few questions About my D16Z6 Swap in 1991 crx si
I have a few questions...
I put a Z6 in my 91 crx si.
Im using an Apexi V-AFC to controll v-tec and fuel. Using the PM6 Ecu and si wiring.
I am using the obd0 distributor drilled on ghetto style.
I am also using the Z6 Intake manifold.
I am getting a Cel Code 1 blink which is Oxygen Content. Is this because im using the Z6 Intake manifold and not all sensors are connected?
Can i use it like this? if so what plugs do i connect where?
Also.. Can i use the Z6 Distributor? i purchased a harness that allowed the Z6 Distributor to clip on to the obd0 harness.
Will it cause a problem because i am still using a Pm6 ecu?
Re: Few questions About my D16Z6 Swap in 1991 crx si (Sirex)
Either the o2 sensor is unplugged or not working properly. Reset the ecu and see if it happens again.
jcrredrex2012
04-20-2012 07:00 PM
iwanttogofast
03-07-2008 10:44 AM
Mrock
07-10-2004 11:39 AM
Sirex
04-24-2003 09:12 PM
