Which ecu to run in a b20z 6th gen. hatch
I've heard the stock DX ecu can actually make more power by running a little leaner in the top end. Anyone have any experience with what ecu's work best on a 6th gen. hatch with a b20z?
Re: Which ecu to run in a b20z 6th gen. hatch (Dominican_Kid)
yes your best bet is a chipped P06 (to either PR4 or P75 specs) or PR4/P75/P74 ECU.
indeed the DX P06 works and makes more top end power, but in the partial throttle and cruising it tends to loose alot more power and lean fairly lean.
Re: Which ecu to run in a b20z 6th gen. hatch (eg6ajk)
Just use an LS ecu.
Since I'm willing to bet you got a few LS parts on it
Its basically an LS with more torque
dropd4door
10
06-11-2004 12:06 PM
boywonda
09-21-2003 09:56 AM
B_1_8_hatch
08-11-2002 12:11 AM
