to do list for b18b into 96 dx hatch
what mounts ,i take it i use integra axles,shift linkage,96-98 ls ecu. what else is there? any wires that need to be extended besides hard wiring in a 4 wire o2. what else to make this swap a breeze?Thanks
you will need an a/c bracket from a B-series del sol if you want to keep your A/C. also you need a rear mount from an integra and a driver's side integra mount i believe.
don't forget the intermediate shaft too when you're looking for axles.
Re: (moike)
Allright.
99-00 Si Rear Mount ("T" looking one)
99-00 Si Driver side mount (One that mounts TO the engine)
96-97 Civic Ex 5speed Wiring Harness
Wiring Harness that came with Swap (I think you need it)
Integra Axles
Del Sol Raditor Hoses
LS Ecu
LS Throttle Cable
Buy plenty of Oil, Filters, LOTS of hose clamps, wiring tools.
I think theres might be more. IF you need more info, IM me.
Integra Axles
LS Ecu
LS Throttle Cable
Re: (ransack)
You don't need an EX harness with an LS swap. No Vtec. But the wires are easier to route. If you use the DX harness, you'll need to cut and extend quite a few wires. Not hard though if you know what you are doing.
EK Swap guide in my sig below too.
Re: (Trey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey »</TD></TR><TR><TD CLASS="quote">You don't need an EX harness with an LS swap. No Vtec. But the wires are easier to route. If you use the DX harness, you'll need to cut and extend quite a few wires. Not hard though if you know what you are doing.
EK Swap guide in my sig below too. </TD></TR></TABLE>
yeah you don't need it. but its easy to wire up. Plus if you go VTEC in the future, your ready.
Supahatch
11-15-2005 10:11 AM
fasterthenmost
10-14-2005 07:57 PM
aznphantoms
11-14-2004 04:37 AM
