where can I get a good p72 ecu?
I need to get a p72 ecu to go with my jdm b18c any suggestions out there? Also can I use a usdm ecu on the jdm motor? This motor is going into an 88 crx si btw
Thanks in advance.
Thanks in advance.
Re: where can I get a good p72 ecu? (Redlineracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redlineracer »</TD></TR><TR><TD CLASS="quote">I need to get a p72 ecu to go with my jdm b18c any suggestions out there? Also can I use a usdm ecu on the jdm motor? This motor is going into an 88 crx si btw
Thanks in advance.</TD></TR></TABLE>
first question: any honda junkyard.
second question: yes you can usdm ecu for the jdm motor. in fact it's recommended due to the shitty program on the jdm ecu and speed govenor.
Re: where can I get a good p72 ecu? (sleeperciv)
I've gota P72 ECU, so I should get a Hondata instead? I thought the P72 were a pretty agressive...but I guess i'm just hearing things, eh?
one what year motor are you going to run. any mods that will eliminate the secondary intake butterflies (skunk2 or JG ?)
also since you're going to possibly need to run a harness converter you might be able to run a JDM OBDII P72 ECU as well.
but indeed the JDM ECUs (p72 ) variety do suck big time.
other choice would be a chipped P75 ECU (converted to p72 dohc vtec specs) - knock sensor disabled and vtec and so on is controlled as well. (pm me if you you want one.)
Real JDM P72 Gsr Ecu????? what codes lets you know if its really a JDM ecu or how to tell the differ
Kangolbrand
01-24-2006 04:10 PM
Luserkid
11-27-2003 04:02 PM
