ecu help!
Old Feb 16, 2016 | 09:49 AM
jmoneyalbarran9's Avatar
Default ecu help!
whats up guys ima make this short n simple. i have a 96 civic coup with a b20b motor previous owner put the motor in but the car used to b auto now its manual it has a P2E ecu which belongs to a civic dx but the car sometimes doesnt wanna turn on when it sits. could this ecu be causing the problems? its not the best civic build out there owner cut ALOT of corners with it. for example still has automatic wiring harness.
Old Feb 16, 2016 | 10:05 AM
v4lu3s's Avatar
RTFM
Default Re: ecu help!
The auto harness is fine since it fits the chassis harness perfectly. Id look into testing the main relay and getting a p75 ecu at least
Old Feb 16, 2016 | 10:58 AM
Former User's Avatar
Install the correct ECU for the engine.
Old Mar 1, 2016 | 10:49 AM
ok but the p75 is ob2 if im not mistaking and from what ive been told the motor and trans have obd1 sensors? the trans came from a 92 teggy.
Nismo13s
20
Oct 18, 2016 04:51 PM
jdmh22eg2
Engine Management and Tuning
12
May 10, 2013 02:36 AM
Mr.DC2TurBo
Dec 19, 2004 05:50 AM
