HELP with my engine build
Old Dec 17, 2015 | 03:46 PM
boudi's Avatar
Icon7 HELP with my engine build
hi guys im running a crx -91 with a b18c6 swap new hondata s300
i want to build a all motor engine N/A i would like to be able to rev mabye 10500 rpm so want to keep my original B18c6 crankshaft, i would realy need help finding the best specs for my engine i would like to puch out as much hp as possible im not so good with this kind f numbers so all the help i can get is thankful. i found some parts on the net could you tell me what you think? and what kind of rods i should get and vales vale springs retainers cmshafts and cam gears etc??
Darton M.I.D. Honda Acura B18 Cylinder Sleeves 86mm-87mm 400-180
WISECO FORGED PISTON KIT HONDA B + 8CC 16:1 B18C HEADSHONDA B
+8CC DOME
B18C HEADS
DRAG RACE
16:1
PART #ASC07668
BORE: 3.4252 / 87MM
XYLON SKIRT COATED
COMP HEIGHT: 1.1280
PIN: 8.268 X 2.002 ( INCLUDED)
RING GROOVES: 1.0MM / 1.2MM / 2.8MM
boudi
Dec 18, 2015 06:13 PM
JJTEG
Sep 8, 2015 04:13 PM
sc4dr
Jan 22, 2006 01:43 PM
94CivSi
Oct 6, 2003 02:38 PM
deftones0817
Dec 18, 2002 12:48 AM
