Ckf bypass diagram
Ckf bypass diagram
Does anyone have the wiring diagram for ckf bypass i have 99 civic with 96 spec jdm b18c-r im currently running a p73 jdm ecu but i wanna get the check engine light off and when i run a p72 on there it throw vtec malfunction code and p1337 which is crankshaft position sensor which i have to do the bypass
Re: Ckf bypass diagram
I just did this yesterday and I used this link (.:FFS TechNet:. » ECU & WIRING How-To Articles » CKF Bypass Trick), worked perfectly! Just make sure you cut the wires after the splice going to the sensor. The first article i found said to de-pin the wires and this didn't work.
MOVE OVER
12-29-2005 10:33 PM
onyx00
08-02-2004 02:48 PM
