96 civic with LS sputters Help
Old 12-07-2015, 07:34 PM
existanzcivicb20's Avatar
Icon5 96 civic with LS sputters Help
Car 1997 Civic with a B18B with a P75 OBD2 ECU. engine is stock but I cant get it to run right. Please see the video I posted onto youtube. Also the sputtering also happens when going down the road and trying to cruse at a steady speed. at high RPMs (5000+) it does cut out and revs normal and it idles normally. I cant find a vacuum leak and the fuel filter is new fuel pressure is at 48psi, timing is spot on, spark plugs and wires are good, what else can i check?
The CEL code is P0117 ECT circuit voltage low. And I also can not figure out why i get that code. I have 5 volts to the sensor and good ground. Continuity good from plug to ECU (connector D2)
Old 12-07-2015, 07:40 PM
White_EG1's Avatar
Default Re: 96 civic with LS sputters Help
Did you try cleaning the IACV?
Old 12-07-2015, 08:26 PM
Yes I have and I also swapped it from one of my other engines
Old 12-13-2015, 01:24 AM
Anyone???
greengiant
07-27-2012 03:30 PM
billard
03-22-2011 06:59 PM
alpha_1
12
09-07-2010 04:19 PM
stockegsix
04-15-2010 10:35 AM
hatchback freek
03-04-2008 03:49 AM
Quick Reply: 96 civic with LS sputters Help
