F20b transmission
F20b transmission
I need someone to PLEASEEEEE tell me if I'm using a ek f20b for daily driving and small drag, no time attack or rallycross, just daily driving and occasional quarter mile runs,is the t2t4 trans better for that or h2b trans! Nobody has been able to fully give me the best answer to this so please help!
Re: F20b transmission
Do a google search for Honda Transmission Ratios. There are lots of lists and charts out there with the gear ratios of all B series and H/F series trans. This will give you the info you need to make a decision. Most of the good B series boxes have closer ratios than the H/F series, but there are close ratio H/F also. It really comes down to how available a given trans is for you, how much you want to spend. Of course there are things like the cost of H2B kits and special headers, not closing/closing the hood, engine mounts, axles, etc. Bottom line, the T2T4 will probably be fine for your needs, just not "THE BEST AVAILABLE".
MalarSamCRX
Transmission & Drivetrain
13
07-06-2018 05:28 AM
turboblack2door
06-13-2011 07:17 PM
turboblack2door
06-11-2011 07:57 AM
