Quick EF swap question
Old Nov 28, 2015 | 10:25 PM
90Ef'n9's Avatar
Default Quick EF swap question
I was given B16A2 by my cousin for reasons. I plan on sinking it into my 90 ef hatch, but ive never done a manual swap before. I have a 4-speed manual, and obviously need a five speed for this swap to function. Do i need to use the b series shifter box and cables or will an si's work for the swap?
Old Nov 29, 2015 | 07:17 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Quick EF swap question
Did you get the transmission as well? If so you'll need a cable to hydro kit. Also you'll need to custom weld your shift linkage or get an aftermarket unit.
Old Nov 29, 2015 | 07:20 AM
90Ef'n9's Avatar
Okay. Awesome. Just got a welder from him too, lucky me. Thank you so much.
Old Dec 1, 2015 | 09:53 PM
Bently_Coop's Avatar
Steve at Heart
Get the Hasport linkage and save some time and money. Do you have mounts? I would go with Hasport for that as well. Depending on which transmission you go with cable or hyrdo will depend on which transmission mount is required and if a cable to hydro conversion is required or not.
Old Dec 1, 2015 | 10:08 PM
90Ef'n9's Avatar
Thank alot man. I will definitely check out that idea. And its a cable. I have innovative mounts though, my budfy gave me some.
Old Dec 4, 2015 | 07:28 PM
Steve at Heart
Innovative has the cable conversion too.
Old Dec 4, 2015 | 08:32 PM
90Ef'n9's Avatar
Awesome, and i have both the b16a2 head and the b16a head. Which one is recommended?
Old Dec 4, 2015 | 09:25 PM
bigtimegambler's Avatar
You don't need to buy premade hasport linkage. Such a waste of 150 + shipping dollars. It takes like two hours max to cut and weld the stock linkage. While you're at it, replace the shifter bushings with a polyurethane kit such as energy. The b16a and b16a2 heads are basically the same with slightly different flow properties. If it were me, Id use the b16a head.
Old Dec 7, 2015 | 11:59 AM
Hasport's Avatar
maybe not everyone has access to a welder or posses the skills to cut and weld
Skulinn
Jul 7, 2010 01:22 AM
whokid_911
Sep 18, 2009 10:14 AM
SaM DA Man
May 26, 2007 07:56 PM
IwantAswap
Jul 16, 2003 09:57 PM
fstblkcivic
19
Jun 24, 2003 08:50 PM
