99 civic ex with jdm 96 spec b18c itr - codes please help
i have a 99 honda civic ex coupe with jdm 96 spec b18c itr running on my usdm ex harness to a p73 ecu jdm i use a canadian p72 to read my codes when i connect the obd2 scanner in it reads 3 codes p0135 02 heater bank 1 sensor 1 also p1337 and p1259 i know p1259 is vtec malfunction i removed solenoid and cleaned it up still throwing the code vtec hits sometimes but not all the time when i hit the gas all the way to the ground vtec wont kick at all and if this helps got a skunk2 ultra series im a apexi header which i thnk is stock on jdm b18c a test pipe and a skunk2 exhaust
Re: 99 civic ex with jdm 96 spec b18c itr - codes please help
As for p0135 measure the resistance of the heater circuit on the sensor it self. It should be between 10-40 ohms of resistance. For p0137 you will need a scan tool that displays o2 sensor voltage data.
irunfromcops
07-15-2003 10:08 AM
