H2B Ek keep AC ?
Old Dec 27, 2015 | 09:36 PM
DXJN's Avatar
Default H2B Ek keep AC ?
Greetings all & Happy Holidays,
I have a few questions.
Main Question:
1) With a H22a or F20b is it possible to fit AC & alt without altering my (ek) chassis. I've seen one thread on carolina honda's about keeping ac but do not want to jump into it without understanding more.
2) i need more powa (than a LS) , ik a b-swap is easiest & i have the mounts already . but what can i get the most bang for my buck out of (hp per dollar & hours of operation per dollar) . i was thinking b20v or h/f2b.
3) how difficult is it to run e85 n a ej6
Thank you
Old Dec 27, 2015 | 09:51 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: H2B Ek keep AC ?
1 - If you've seen a thread on it, then obviously it's possible. Maybe you should read that thread if you want to understand it more?
2 - FAQ sticky. Covered in excess.
3 - Easy - just get it tuned for it. You'll need bigger injectors, and you'll gain exactly nothing from it on a stock or near-stock motor.
Old Dec 27, 2015 | 10:33 PM
DXJN's Avatar
thanks for the reply
1) many things prohibit me from doing that , its only 1 thread that'd i'd join the forum for, its old & would like to see others who had done it. the thread wasnt in detail
2) i'll have to look into it more , im between b20v high comp & stock h/f
3) would the corresponding senors need to b changed or calibrated ? (O2)
Old Dec 28, 2015 | 04:56 AM
tony_2018's Avatar
Fish Twig
Custom lines....
Old Dec 28, 2015 | 06:47 AM
DXJN's Avatar
Originally Posted by tony_2018
Custom lines....
i'll give u 100 bucks. make me some.
It seems like the Alt relocating bracket for a H2b swap takes the AC's place , anybody have any info ?
Old Dec 28, 2015 | 06:48 AM
tony_2018's Avatar
Fish Twig
ROFLMAO....no.
Old Dec 28, 2015 | 08:04 AM
scottcraft's Avatar
10 Year Member
Loved
Community Favorite
Search for a forum member named libertariat. He's got an ek hatch with an h22 and a/c. He's got a thread that talks about how he did it.
Here's the thread:
https://honda-tech.com/hybrid-engine...-done-3042110/
Old Jan 1, 2016 | 05:54 PM
n*werk's Avatar
Old Jan 4, 2016 | 06:17 AM
DXJN's Avatar
O wow , thank you for the help. I'll check it out rn.
Old Jan 4, 2016 | 06:40 AM
hondamark35's Avatar
I had a local hose building shop quote custom lines (the two flex that run to the compressor) a year or two ago and the total was about $120. not bad as factory replacements are about the same.
even with a slim fan (which will require fabrication of a standalone condenser mounting solution) space is tight. the best bet is to have a fabricator (or if you are capable yourself) replicate the factory (for the Accord/Prelude) arrangement to fit. so a pivoting alternator above the rigid-mounted compressor as close to the block as possible.
Old Jan 4, 2016 | 11:24 PM
Bently_Coop's Avatar
Steve at Heart
This guy did it on here. A former mod. @Libertariat
jayWknight
Nov 18, 2011 12:31 PM
therockethatch
K Series
Sep 4, 2010 01:32 PM
MurtazaDSM
Jul 25, 2009 11:30 PM
Spec C
Feb 11, 2005 07:05 AM
