In need of help.
Old Dec 20, 2015 | 04:19 PM
basketgrl63's Avatar
Default In need of help.
Hi everyone. I am having problems and looking for an answer.
I have a 92 Honda civic I recently put a 95 prelude engine in my car (h22a1)
I am having problems with my passenger side axle. It keeps popping out of my trans. I am hoping we fixed the issue but I was told to "Frankenstein" an axle with the trans side of the axle of a prelude and the outside of a civic.... Does this sound right? Can someone help me please. I am hitting a wall and really need my car for work.
Old Dec 20, 2015 | 09:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: In need of help.
Yes, using the Integra "B" series axle has a problem with the "H" transmission. The splined part is actually too short, so the snap ring doesn't seat in the groove inside the transmission's differential. This is the reason that you MUST use the H22/F22 inboard joint cup and the rest of the "B" series axle.
Old Dec 21, 2015 | 02:46 AM
I can't just buy one that way..correct? I will have to get both and make one out of the two of them?
Old Dec 22, 2015 | 11:01 PM
h22god's Avatar
Hasport, Yonaka, insane shafts, DSS, all sale axles for a eg with a H/F swap. Use the correct mid shaft for the axles you buy if it doesn't come with it.
Old Dec 23, 2015 | 09:10 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The most affordable quality options will be from HASport and Raxles... found in Arizona and Florida respectively. Look them up, they will take care of you.
h22sedan
Aug 6, 2010 02:54 PM
ef9tuner
Jun 15, 2010 11:42 AM
djsire
Apr 7, 2006 09:39 AM
tibbor
Nov 26, 2003 10:30 PM
