engine choice track car
Old Jan 28, 2016 | 11:28 AM
honda-damien's Avatar
Default engine choice track car
hello,
a couple of monds ago i made the choice to start building a track/time attack/ weekend racer out of my ej9.
now the suspension of the car is almost compleet for heavy abuse now i need to make a choice what engine i want to run.
at first the idea was to drive a build d16z6 turbo because of the weight
but i want to know other options and experiences from people i had a couple of ideas myself.
b18b/b1 turbo the only thing is this engine is almost imposible to find here in europe.
b20 with vtec swap + bolt ons what i read good power but weak cilinder walls??
b18c with bolt ons heard good things about his engine only thing is alot of people driving this and i like to be different
h2b swap good strong engine's but on the other side relatively heavy causing oversteer.
k swap good power and al lot of potential but high cost for the swap
this where a couple of ideas i had myself so now i'm looking for driving exeriences and opinions about handeling and driving it on the track.
this project is not the typical low budget build i want to take time to do the right thing the first time and i'm prepared to put much time and money in the right engine.
Old Jan 28, 2016 | 03:54 PM
B-Serious CRX's Avatar
Default Re: engine choice track car
I would in my opinion do a b18c turbo . I'm going to do this for my street / track crx . currently have a b18a1 makes good power with bolt ons. Runs good and handles well with everything .
Old Jan 28, 2016 | 09:53 PM
The b18c is a good option especialie because in a couple of weeks i get an 98 itr for breaking.
But in combination with a turbo wil it be a reliable engine because of the high compresion and the cilinder walls That can turn oval.
But if i sleeve the Block and build it isnt there a beter option for the money i wil put in building the engine to build it.
Old Feb 5, 2016 | 04:57 AM
jayswizz's Avatar
what are your power goals?
Old Feb 10, 2016 | 04:58 AM
I'm aiming for 250whp but with the option to build further to go to 300 or even more.
Old Feb 15, 2016 | 08:36 AM
jayswizz's Avatar
a b20v will get you to 250 maybe a little higher but they do not like boost at all, cyl walls are extremely week, so if your goal is to be at 300 or over go for a gsr, b16, or ls vtec if you can find a block for it. those will all make 300 on stock internals
Old Feb 23, 2016 | 12:27 PM
Found an b16a1 complete build for turbo use i think this is gonna be the engine i wil use.
In combination with a twin scroll turbo i Will hit my 250 whp goal without a problem.
And its having potential to go higher for for a total pricé of 3th of an k swap.
Old Feb 23, 2016 | 01:13 PM
the171's Avatar
A Stock engine is hard to beat. Runs good and you gotta work it hard to overheat. Any engine can work. B series, H series, k series can all be fast.
Jared
Other Make Vehicles
88
Jan 24, 2017 05:02 PM
wagoman17
Nov 11, 2015 11:08 PM
mike333
Sep 24, 2010 10:39 AM
Hyjnx
Nov 8, 2002 06:46 PM
FourthGenHatch
26
Sep 17, 2002 04:14 PM
