Distributor & idle issue
Old May 11, 2016 | 12:50 AM
hondamyheart's Avatar
Default Distributor & idle issue
Recently my car idles rough and engine sputters randomly at different RPMs. I noticed that if I wiggle the distributor wires the car idles better. I took the boot of the wires but they look fine. Could it be connector problem?
Old May 11, 2016 | 01:28 AM
hoopty hopper's Avatar
Default Re: Distributor & idle issue
if your obd1 rotating the distributor advances (rpm's go up) and retards(rpm's go down) the timing, obd2 usually the ecu will autocorrect timing within its own parameters and the distributor should be bolted down so you cant just turn it by hand.
as for rough idle issues just that isnt enough info to go on. if your timing is too retarded itll sputter and run horrible. too advanced and you might end up hating life later down the road.
what is your idle rpm? what all have you done to correct it? do you have a check engine light on? does it idle rough when its hot cold or both? is it misfiring? when was the last time you changed sparkplugs and wires,cap and rotor,? are the spark plugs all fouled up or have improper gap setting what brands are they? cheap brands like autolite dont usually come properly gapped and need to be gapped. have you tested your spark wires to make sure theyre within spec? what fuel do you use and have you done a fuel contaminant and quality check? do you lack power on the highway but good around town? the more info you give it helps narrow down the 21 questions game.
Old May 11, 2016 | 01:58 AM
JarvisW's Avatar
Sol to Sol
WHICH dizzy wires are you talking about?
The plug wires (because you said boots?)
Or the harness?
ALSO, You are required to post the year/make/model, and engine, mods, etc in the OP. (if I didnt say, someone else will )
Old May 11, 2016 | 05:50 AM
Thanks guys for your replies. I am attaching an image of which wires i mean.
Car: EJ6
Model: 2000
Engine: H22 Manual
ECU: P28 chipped (h22 basemap)
Fuel Used: 95 Octane
Parts Replaced this year:
-Walbro fuel pump 255.
-Fuel Filter.
-Fuel Regulator.
-(NGK Spark Plugs),wires,cap and rotor.
-New Battery.
-New Radiator & Fans.
i tried to start the car in the morning and it just cranks, car i s getting fuel. I popped up the hood trying to figure out what happened. I just wiggled the dizzy wires and the went back to car and it just starts! but it idles rough,misfires. So i took it for a drive and it was sputtering at different RPMs. I went back home and wiggled the wires again and it idles better! I shut the car and took the boots off but they look fine. I checked for codes NO CELs.
Old May 11, 2016 | 06:04 AM
mk378's Avatar
Unplug the plugs and look for corrosion or damage to the connector pins. You may need to replace the distributor and/or harness plugs.
Test by idling the car while you move the wires carefully one at a time to try and localize the problem.
Old May 12, 2016 | 12:08 AM
I'll check tomorrow and post an update.
Thanks.
redm3turbo
Jul 25, 2015 08:34 AM
Kyogie12
Dec 18, 2011 05:48 AM
sythe21
Oct 21, 2011 05:30 PM
trevek10
May 16, 2011 03:07 PM
bassysingh
Oct 17, 2005 10:02 AM
