97 Civic/B18c1 swap - IAT code 10
Old 05-29-2016, 08:08 AM
tomgreene's Avatar
Default 97 Civic/B18c1 swap - IAT code 10
Hi guys. i swapped my 97 coupe with a gsr and i have hondata s300 v2. I threw a code 10 for iat so i took the iat out and sure as **** is was melted. so i replaced it with another iat that works fine. when the car is running now i can unplug the iat and hear the difference in idle. so i know it works. how come i am still throwing the code. even when i reset the codes in hondata the light comes right back on. Anybody know what im missing? Thanks
Old 05-29-2016, 08:37 AM
Former User's Avatar
Default Re: B18c1 IAT
Sounds like you may have some swapped sensor connectors, which often blows the ECU.
Old 06-01-2016, 02:45 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: 97 Civic/B18c1 swap - IAT code 10
Did you reuse the Civic one or rewire a connector to use the GSR one?
tomgreene
06-01-2016 02:44 AM
BobMack
11-14-2011 07:24 AM
252564
09-05-2010 08:30 AM
mouab18c1
07-18-2010 08:16 PM
Quick Reply: 97 Civic/B18c1 swap - IAT code 10
