will a stock CRV K24 + K20A2 head be ok on the race circut, or only for drag racing?
i am def. doing a K conversion in my VTiR DC2,
i have a full K20A2 and a full K24A1 and a 5 speed K tranny and will be using Hondata K100 ecu...
i love the concept/potential of 86x86 bore/stroke, but i am tempted by the idea of HEAPS of torque with the 'stupid big' K24 99mm stoke.
but has anyone used a K20/K24 for continuious high RPM circut racing ie 10+ full noise laps etc...
i have built a B20VTEC before (stock internals) and have reved it over 8500 on the circut without drama, on one track day i had rev limiter set to 9k and it felt fine.
the B20B R/S ratio is similar to the K24A R/S ratio (1.54ish), so can i compare apples to apples or is the K inheirently different to the B series frankies???
any input would be most welcome
Re: (bluebird)
the R/S ratio has little to do with the revibilty (aspecially in this extremity of cases)
the 99mm stroke forces the piston to travel that distance per one half revolution, and a lower 86mm would be that in one half also. therefore at the same RPM, your 99mm engine will be putting more force on the rods, piston pins and pistons.
if done right, its not a huge problem; however i dont see 10,000rpm comming from it without a crazy lot of money invested
Modified by nickzed20 at 6:36 PM 11/27/2004
Re: (tinkerbell)
r/s ratio dosnt matter... piston speed is far more important than r/s..
99mm stroke is gona create some REALLY high piston speeds and stuff will break.
id stick w/the k20
id stick w/the k20
Re: (JDogg)
so piston speed is the real concern!
the bore/stroke ratio is also aweful - (i just worked out)
B18A = 0.91
B81C = 0.93
B20B = 0.94
F20C = 0.96
B16A = 1.05
K24A = 0.87
K20A = 1.00
bore/stroke ratio is a good indicator of piston speeds and also revability - with anything over 1 being a great revver at the sacrifice of lowend torque.
so yeah, the k24 = torque the k20 = revs + top end power
B18A = 0.91
B81C = 0.93
B20B = 0.94
F20C = 0.96
B16A = 1.05
K24A = 0.87
K20A = 1.00
Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">that has nothing to do with how well it will rev.....</TD></TR></TABLE>
really?
on what basis do you make this comment?
really?
Re: (tinkerbell)
think about it... why would a change in the bore (how big AROUND the piston is) have anything to do with revability..?? what does it tell you about piston speed... NOTHING. look at ur math... b20b and b18b have different bore/stroke ratio, but they will have the SAME piston speed because they have the same rod and hte same stroke.
the reason it might "seem" that a bore/stroke ratio might matter is because the only way to get any displacement and still have acceptable piston speed is to have a bigger bore. stroke is the biggest factor in revability of an engine and the only one you need to be conserned with.. period.
Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">think about it... why would a change in the bore (how big AROUND the piston is) have anything to do with revability..?? what does it tell you about piston speed... NOTHING. look at ur math... b20b and b18b have different bore/stroke ratio, but they will have the SAME piston speed because they have the same rod and hte same stroke.
so a engine with a 86x86 bore/stoke will have the same piston sideloading as a engine with a 50x100 bore/stoke?
and be able to rev as high?
why do F1 engine have bore/stoke close to 100x50 and rev to 18'000rpm?
you say bore or 'aroundness' doesnt have any effect on revability?
i think it might...
i think it might...
Re: (tinkerbell)
f1 engines ahve a huge bore and a small stroke... similar to motor cycle engines. they are like that simply because they need the short stroke so the engine can rev. the big bore is so it will have enough displacement... it has nothing to do with revability...
Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">f1 engines ahve a huge bore and a small stroke... similar to motor cycle engines. they are like that simply because they need the short stroke so the engine can rev. the big bore is so it will have enough displacement... it has nothing to do with revability...</TD></TR></TABLE>
oh, OK.
oh, OK.
COBB Tuning
Northwest
05-10-2010 10:57 AM
Catch 22
43
12-16-2005 02:49 PM
FAST94GSR
06-17-2002 01:10 PM
