vtec issues
Old Nov 24, 2004 | 03:35 AM
GhettoR's Avatar
Default vtec issues
Just got the swap done and have one problem that is bugging me. Motor is 97 C5 and has CTR intake cam, skunk2 gears and ecu, aem filter, b/m fuel regi(which was set to 57 psi). First the problem, when in vtec the motor is fine until coming out where it bogs down until 4k rpms. It seems to fix and goes back to normal, the motor also pops. I have adjusted the fuel pressure down to 40 psi but it still happens. Replaced plugs with ngk iridium, msd wires and stock cap for now. What is happening?
Old Nov 27, 2004 | 01:33 PM
GhettoR's Avatar
Default Re: vtec issues (ONELOVEB)
Problem fixed, it was the exhaust cam timing was a little off. Running good now
F20BEK
Feb 11, 2008 11:27 AM
jizno
Mar 2, 2006 03:04 PM
PIC Performance
May 10, 2005 08:50 PM
GhettoR
Nov 26, 2004 06:18 PM
B00ST2nR
Aug 1, 2002 08:35 PM
