wiring gsr into eg
wiring gsr into eg
Does the yellow black wire of the IAB go to pos switched 12v source or to ground.
Modified by NitrousB.I.G. at 5:55 AM 11/23/2004
Re: wiring gsr into eg (NitrousB.I.G.)
depends on obd1 or odb2.. if its a obd1 motor using a obd1 ecu, you can switch pins..hhmm cant remember which one, this one is widley preached so go search. if its a obd2 motor using obd1 ecu you can splice into the IAB solenoid and run it straight to the ecu to one of the injector pins. it works. so dont knock it til you try it.
Re: wiring gsr into eg (eh2+b18c1=usdm sleeper)
Run the wire to this connector (the one with the red dot) and tap into one of the wires:
That is 12v igntion power. Then run the other to A17 (OBD1)
tony7626
11-02-2009 06:36 AM
Project92Hatch
05-09-2003 03:11 PM
