ECU pinouts B20/VTEC
What pinouts should i use, im using a b20a block with a gs-r head and ls tranny. I need the pinouts i would use when im using the gs-r ecu.
BANNED
Re: ECU pinouts B20/VTEC (Pr0jektLude)
huh
this is a noobie question it all depends in ur set up
What car?? What harness??? What gen motor???
I would try searching next time
Re: ECU pinouts B20/VTEC (krazie1)
im using a b20 block in a 90 prelude, with a gs-r head from a 94 g3 and i got the wiring harnees obd1 with a p72 ecu i got all the pinouts but "D12"- it says its a yel/grn wire but no description? what wire is this? And is the pinouts for a p72 obd1 goin to work for this setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0jektLude »</TD></TR><TR><TD CLASS="quote">im using a b20 block in a 90 prelude, with a gs-r head from a 94 g3 and i got the wiring harnees obd1 with a p72 ecu i got all the pinouts but "D12"- it says its a yel/grn wire but no description? what wire is this? And is the pinouts for a p72 obd1 goin to work for this setup?</TD></TR></TABLE>
Are you attempting to use the b20a in the prelude with the vtec head?
