b16a2 swap help>>>
Old Nov 21, 2004 | 07:14 AM
DOHC HX's Avatar
Default b16a2 swap help>>>
NOW LETS TRY THIS AGAIN... SORRY ABOUT THE LAST ONE...
i'm droping a b16a2 into my 97 hx!
what wiring harness can i use?
if i get a ex harness what ecu do i need. And can i use a p30 or
can i just use the si harness and ecu?
and do i need to run any wiring?
any help would be apriciated...
Old Nov 21, 2004 | 08:45 AM
DOHC HX's Avatar
Default Re: b16a2 swap help>>> (DOHC HX)
anyone....
Old Nov 21, 2004 | 04:25 PM
DOHC HX's Avatar
some help please
Old Nov 21, 2004 | 04:59 PM
LS_DON4500's Avatar
search up first, a few good clean ways to do it!
Old Nov 21, 2004 | 11:56 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC HX &raquo;</TD></TR><TR><TD CLASS="quote">
you can technically reuse your HX harness (which is almost like an EX harness), but you'll have to modify the 02 sensor wiring being that an HX has a 5-wire 02 sensor (a B16 engine uses a 4-wire 02). Or you could use a 96-98 5speed EX engine harness and everything will be plug n play compatible providing that you have an OBD2 B16 engine.
You CANNOT use the Si harness because its OBD2b spec (your car is OBD2a, the wire harness differs).
If the P30 ecu is OBD1, you can run it, but you'll need to get an OBD2a -&gt;OBD1 ecu jumper harness (which i suggest you do).
any help would be apriciated...</TD></TR></TABLE>
Old Nov 22, 2004 | 05:24 AM
reemo_2001's Avatar
Default Re: b16a2 swap help>>> (K@man)
You can use the P30 or p28 but you'd have to get a jumper harness to go from obdII to obdI. Just use the p2t, it plugs right into your ecu harness w/out getting the jumper.
Old Nov 22, 2004 | 11:04 AM
Katman's Avatar
Default Re: b16a2 swap help>>> (reemo_2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reemo_2001 &raquo;</TD></TR><TR><TD CLASS="quote">You can use the P30 or p28 but you'd have to get a jumper harness to go from obdII to obdI. Just use the p2t, it plugs right into your ecu harness w/out getting the jumper.</TD></TR></TABLE>
....He will still have to run an ecu jumper (OBD2a-&gt;OBD2b) jumper harness to use an Si (P2T) ecu
And again, if DOHC HX's B16A is OBD1 spec (which I think a B16A2 is), he will run into problems when using any US OBD2 ecu with this OBD1 engine i.e. codes for the CKF & 2nd 02 sensor (CKF being the most problamatic sensor to deal with).
He should really choose to convert to an OBD1 ecu if he uses an OBD1 engine, unless he plans to buy a US OBD2 oil pump w/CKF sensor = $$$.
Old Nov 22, 2004 | 06:45 PM
DOHC HX's Avatar
THANKS FOR ALL THE HELPS GUYS THAT SHOULD HELP ALOT...I HAVE A 97 EX HARNESS AND MY MOTOR CAME OFF A 99 CIVIC...SO ALL I NEED NOW IS A OBD II TO OBD 1 JUMPER
Old Nov 23, 2004 | 01:18 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC HX &raquo;</TD></TR><TR><TD CLASS="quote">...SO ALL I NEED NOW IS A OBD II TO OBD 1 JUMPER</TD></TR></TABLE>
I have this jumper available for sale if your interested -- IM me..
Novtecdohc
Oct 11, 2005 08:13 AM
naman
Mar 20, 2004 05:37 PM
CB_ejcoupe
Jun 5, 2003 11:28 PM
jcivic
Mar 1, 2003 06:16 PM
Bezerker
Oct 3, 2002 09:15 AM
