Which BrakeLines Do I Use?
Old Dec 1, 2004 | 05:03 PM
integlspwr2k's Avatar
Default Which BrakeLines Do I Use?
Gonna Make this short.
96 HX Coupe
00 GSR Brakes Front & Rear
Which Stainless Steel Brakes lines do I buy?
Thanks In Advance...
Old Dec 1, 2004 | 05:12 PM
slammed_93_hatch's Avatar
Default Re: Which BrakeLines Do I Use? (integlspwr2k)
the ones for the caliper you are using
Old Dec 1, 2004 | 05:56 PM
Default Re: Which BrakeLines Do I Use? (slammed_93_hatch)
so you match the brake lines to the capliers and not to the chasis?
Old Dec 1, 2004 | 09:50 PM
Weston's Avatar
I'm assuming you already have rubber lines installed... are they from an Integra or a Civic?
Old Dec 1, 2004 | 10:05 PM
Default Re: (Weston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weston &raquo;</TD></TR><TR><TD CLASS="quote">I'm assuming you already have rubber lines installed... are they from an Integra or a Civic?</TD></TR></TABLE>
no i do not have the rubber lines installed. I am going to do the swap when my b16 motor and turbo go in. So everything will be done at the same time.
Old Dec 1, 2004 | 10:27 PM
Default Re: (integlspwr2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">the ones for the caliper you are using</TD></TR></TABLE>
you use the brake lines for the caliper you are using.
if your using integra 94-00 non type R calipers you use those brake lines.
Old Dec 1, 2004 | 11:02 PM
Default Re: (slammed_93_hatch)
if your using integra 94-00 non type R calipers you use those brake lines.</TD></TR></TABLE>
sounds good. i was almost going to be 99-00 Si ones. but if integra ones will work. Then thats the ones im getting.
Old Dec 2, 2004 | 03:36 PM
smart monkey's Avatar
I would use the 99-si ones cause the teg ones don't have the same mount points on the front lines for the shock mount. the rear however should be the same between the 99-si and 94-tegs.
Old Dec 2, 2004 | 04:16 PM
Default Re: Which BrakeLines Do I Use? (smart monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smart monkey &raquo;</TD></TR><TR><TD CLASS="quote">I would use the 99-si ones cause the teg ones don't have the same mount points on the front lines for the shock mount. the rear however should be the same between the 99-si and 94-tegs.</TD></TR></TABLE>
SS lines are owned by Zip tie mounting
Old Dec 2, 2004 | 04:53 PM
SS lines are owned by Zip tie mounting</TD></TR></TABLE>
sounds good.. Integra ones im gonna get.
Old Dec 2, 2004 | 10:03 PM
blackeg's Avatar
mad props to the zip tie. i got itr lines on my ek/ls knuckles and im gonna zip tie them to the back of the knuckle because they are hella long
.BigSexy
Apr 8, 2007 05:42 PM
StatGSR
Apr 28, 2005 12:55 PM
jefe
30
Dec 11, 2004 12:41 PM
anekin007
Sep 30, 2004 07:47 PM
