Do I need tochange axles when converting to ITR brakes?
I am thinking about converting over to 96 spec ITR suspension on my 95 civic coupe. It has the stock d series in it. Do I need to change the axles?
thanks
thanks
no, you dont need to change axles, you can keep using your exsiting axles with US ITR 5lug conversion. Altho, there would be a problem if you wanted to use 98+ JDM ITR 5lug (uses a 36mm axle spline).
Re: (dpine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpine »</TD></TR><TR><TD CLASS="quote">does the itr 4X114.3 suspension use 36mm axles like the jdm 5 lug?</TD></TR></TABLE>
nope.
nope.
Re: (K@man)
So bacically your saying I can use the 4X114.3 itr suspension on a 95 civic with a d series motor and not have to change the axles.
Are there any differences between manual trans axles and auto axles? its an auto civic.
snowboardgeek1
10
09-04-2007 09:07 PM
