Meters in a N/A setup.... HELP
Old Dec 1, 2004 | 11:50 PM
mdj_ge's Avatar
Default Meters in a N/A setup.... HELP
i plan to put in some meters.... but what are some good meters to put in a N/A setup???? i mean, other than Air / Fuel ratio... what are other important meter i should put in there.... thanks in advance...
Old Dec 2, 2004 | 04:00 PM
mdj_ge's Avatar
Default Re: Meters in a N/A setup.... HELP (yangja)
anyone out there with meters???
Old Dec 2, 2004 | 05:01 PM
racinategra's Avatar
what setup are you running? I run ls vtec and the two most important are oil pressure and a/f ratio
Old Dec 2, 2004 | 05:29 PM
mdj_ge's Avatar
Default Re: (racinategra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinategra &raquo;</TD></TR><TR><TD CLASS="quote">what setup are you running? I run ls vtec and the two most important are oil pressure and a/f ratio</TD></TR></TABLE>
I have a h22 swap right now.... everything is just stock....
Old Dec 2, 2004 | 06:52 PM
honda_joe's Avatar
WIDEBAND A/F sensor
The $30 autometer one will just give you a light show. To get an ACCURATE reading, you need a Wideband O2 sensor setup from PLX, Innovative, etc.
Old Dec 3, 2004 | 04:16 PM
mdj_ge's Avatar
Default Re: Meters in a N/A setup.... HELP (honda_joe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_joe &raquo;</TD></TR><TR><TD CLASS="quote">WIDEBAND A/F sensor
The $30 autometer one will just give you a light show. To get an ACCURATE reading, you need a Wideband O2 sensor setup from PLX, Innovative, etc. </TD></TR></TABLE>
thanks for the advice... i plan on getting the 3 pod what other meters should i get???
Old Dec 8, 2004 | 09:06 AM
Adam.'s Avatar
coolant temp and oil pressure gauge.
Old Dec 8, 2004 | 08:29 PM
endlesswinterco's Avatar
Default Re: Meters in a N/A setup.... HELP (DarkKnight[DMD])
oil and even egt, or wide band
Old Dec 9, 2004 | 01:08 AM
@ries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD &raquo;</TD></TR><TR><TD CLASS="quote">]coolant temp and oil pressure gauge.</TD></TR></TABLE>
i concur.. defi blackface.
Old Dec 9, 2004 | 06:36 AM
Default Re: Meters in a N/A setup.... HELP (@ries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries &raquo;</TD></TR><TR><TD CLASS="quote">
i concur.. defi blackface.</TD></TR></TABLE>
yea if your a baller. autometer, greddy work just as good
jdmweaked
Aug 5, 2008 02:28 PM
DavidTurbo
Oct 9, 2006 06:31 PM
B00ST2nR
Apr 25, 2005 05:48 PM
ultracrx
Mar 16, 2005 08:18 AM
nuro
Nov 14, 2003 06:48 PM
