LS VTEC Disributor Question
Old Nov 30, 2004 | 03:09 PM
racinategra's Avatar
Default LS VTEC Disributor Question
What distributor should i run. I am running ls vtec with a b16 head and a pr3 ecu. Help!
Old Nov 30, 2004 | 06:12 PM
KtotheEK's Avatar
Default Re: LS VTEC Disributor Question (racinategra)
alex you dont need a new distributor, you already run 13's on street tires i dont see waht could be soooo wrong with your current one
Old Nov 30, 2004 | 09:57 PM
mtber's Avatar
You would run a vtec distributor, but it would have to be the same obd series as your wiring harness/ecu. So I am assuming you would need a obd0 vtec dizzy.
Try distributorkiing.com or ebay.
Old Nov 30, 2004 | 10:17 PM
triple_s1x's Avatar
Default Re: LS VTEC Disributor Question (mtber)
You can use either a vtec or ls dizzzy, if your gonna use a non vtec dizzy on a vtec head you need to chop off one of the mounting tabs.
Old Dec 1, 2004 | 09:53 AM
thanks guys
Alexpbnj
May 16, 2011 04:36 AM
D-rush08
Sep 7, 2006 10:08 AM
Speed94
Mar 18, 2005 08:19 PM
91hatch_on17's
Jun 25, 2003 10:26 PM
made in JAPAN
Dec 11, 2002 07:01 AM
