LS/VTEC QUESTION
Old Nov 26, 2004 | 06:25 AM
92eg'n's Avatar
Default LS/VTEC QUESTION
Would it be better to keep the stock crank w/ itr pistons and rods..or should I use a gsr crank w/ itr pistons and rods...or if anyone has any suggestions let me hear thanks in advance for any info provided
Old Nov 26, 2004 | 07:15 AM
92eg'n's Avatar
Default Re: LS/VTEC QUESTION (92eg'n)
Old Nov 27, 2004 | 11:19 AM
Integralove00's Avatar
Using the GSR crank would eliminate half of the concept of the LS/Vtec. That half being you would shorten the stroke since the GSR stroke is shorter than the LS. I don't remember the outcome of the R rods with LS crank a deck plate might be needed. If you use a Vtec head on a B18B block with GSR internals you have a GSR motor minus the oil squirters and girdle. You need to do research and not try to be spoon fed the answers are all over the internet and on Honda-Tech.
Old Nov 27, 2004 | 02:20 PM
Tuesday Club's Avatar
Default Re: LS/VTEC QUESTION (Inte9ralove00)
^what he said
b18psi
Sep 20, 2006 04:15 PM
dominicanvtec
Mar 9, 2005 11:19 AM
dornon13
Aug 27, 2004 06:23 AM
EH2LS
Apr 29, 2004 08:24 AM
hondamann_p28
Dec 20, 2003 09:25 PM
