HELP!! ABS light on. k20a into dc2.
I don't know why my abs light is on. What can i check to see if everyting is ok? i unplug the abs pump recently and plug it back up (just the plugs). it's all plug in now. i also took out the front brake rotor before it happen. Any idea how to fix this problem.. thanks...
Re: HELP!! ABS light on. k20a into dc2. (TypeR0186)
I think maybe, the axles you possibly used for your K20 swap do not have the metal ring around the outter joints (cups) which the ABS sensor needs to read from, which in turn will throw an ABS light.
Re: (v4lu3s)
ohh and i don't have the link connector hooked up yet. if i try to read it by the check engine light blinking way it only reads "serial connector link" missing.
hrm maybe it is unhappy with the wiring being missing only then?
i know when my wifes lude had abs probloems i jsut put the jumper in and counter flashes on the abs light, though in her case it was a bad wheel speed sensor.
