LS Vtech
Old Nov 19, 2004 | 10:53 AM
ITR.#1446's Avatar
Default LS Vtec
I tried searching and only came up with probs people had but i need to know everything that you would need to do this, all the parts and some info. My brother and i want to make his 93 ls into a ls vtec so if you guys have any info please help us out. thanks
Modified by ITR.#1446 at 9:30 AM 11/23/2004
Old Nov 19, 2004 | 02:07 PM
Shoobie's Avatar
Default Re: LS Vtech (ITR.#1446)
Vtech makes telephones, so that may be the problem. Try searching for LS/VTEC.
Old Nov 20, 2004 | 09:11 AM
bluebird's Avatar
Default Re: LS Vtech (Shoobie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shoobie &raquo;</TD></TR><TR><TD CLASS="quote">Vtech makes telephones, so that may be the problem. Try searching for LS/VTEC. </TD></TR></TABLE>
LOL .... Vtech
Old Nov 20, 2004 | 06:26 PM
Hapexamendios EJ8's Avatar
Default Re: LS Vtech (bluebird)
lol you and your bro got a problem, no such thing as ******* vtech...lol
well... cept for the phone.. but thats no fun to drive huh?
Old Nov 22, 2004 | 05:32 PM
DC-4-Drew's Avatar
Default Re: LS Vtech (Hapexamendios EJ8)
I would edit the Vtech thing VERY QUICKLY to avoid super flame!! But to answer your question Super Street and Sport Compact Car both withing the last 2 months shows the basics of the LS/Vtec swap. Here is a basic list of what you will need:
Block b18
b18 Crank
Either CTR or Pr3 Pistons depending on what CR you want to run
Rings
Rods You can use Ls rods but they will only be able to hanld about 220 horsepower.
Bearings
GSR or B16 Vtec waterpump
Timing belt for GSR
tensioner
oilpump GSR
Manifold,Intake Can reuse the stock
Manifold,Exaust Can reuse the stock
ECU
Main bolts
Head gasket for LS
dowels 13x20 Dowels for the Crank Girdle
Head bolts
oilpan GSR
Crank Girdle from GSR (you will have to get the main caps machined to fit on the Oem crank girdle. You will also need to have the Top of the caps machined to accept the dowels.
Windage tray GSR
oil pickup GSR
Oil pan gasket B18
Vtec oil line Kit
motor work including honing of the cylinder walls, balancing crank(VERY IMPORTANT), and so forth.
You can use the search feature for LS/Vtec and you will find many resources to help you out on this. I would watch out using that Vtech, you will get harrased to death for that. I hope this helps you out. I am getting ready to send my motor off to the machine shop and I am excited.
Old Nov 23, 2004 | 12:31 AM
ITR.#1446's Avatar
Default Re: LS Vtech (b16a3delsol)
thanks for the info bro i appreciate it
Old Nov 23, 2004 | 11:14 AM
saleensolution's Avatar
im sorry man i couldnt help it
but there is several things you will need there are plenty of web sites that do a step by step procedure to do it
heres one http://www.c-speedracing.com/h...c.php
good luck
Old Nov 23, 2004 | 03:58 PM
jdmracer420's Avatar
lol, I love the pics
Old Nov 23, 2004 | 06:57 PM
UnKnownUser's Avatar
Default Re: (jdmracer420)
When the **** are you going to get it straight,when is everyone going to get it straight?How the **** you get vtech?
Modified by LSVTEC_DC4 at 10:01 PM 11/24/2004
Old Nov 24, 2004 | 03:03 PM
DC-4-Drew's Avatar
Default Re: (LSVTEC_DC4)
calm down killer.....he knows......
Old Nov 24, 2004 | 08:56 PM
BoostedJeff's Avatar
I bought my JDM VTECH at pep boys, yo!
WhoneedsVtec7g'sISplenty
Mar 14, 2006 10:07 AM
xgenn786
Sep 25, 2005 10:28 PM
Rpizzle
Mar 11, 2005 10:09 PM
westspeed
Jan 26, 2005 11:54 AM
RSVTECDC4
Jul 19, 2003 06:05 AM
