question on mc and brake booster swap question
Old 11-18-2004, 04:20 PM
racekar's Avatar
Default question on mc and brake booster swap question
i searched but i couldnt find the answer,
i purchased a complete f/r integra gsr brake swap from import auto salvage.
but i didnt get the MC. would i be able to use a 91 ciiv ex 4 door mC since its 15/16th with the integra brake booster or do i have to use a civic brake booste thanks! OR would i have to use my stock civic booster? If i did this does anyone know if the brake feel is worse than using an integra MC/booster?
or can i buy a RS integra master cylinder and use it with a gsr brake booster??? thanks
Modified by dchung1 at 5:47 PM 11/18/2004
Modified by dchung1 at 5:56 PM 11/18/2004
Old 11-18-2004, 04:48 PM
racekar's Avatar
upp
Old 11-18-2004, 04:57 PM
racekar's Avatar
upppp
Old 11-19-2004, 06:00 AM
91civicDXdude's Avatar
i dont know if this applies to your situation, but i'll throw it out anyways...
I have a 91 hatch. I parted out a 91 teg. I took the 15/16 master cylinder and was going to bolt it to my 91 hatch stock booster. Then i foudn out that the 91 teg bolts the opposite way, so using a 90-91 teg master cylinder on EF civic, you need to use the 90-91 teg booster too.
Now, the dilema..
My friend has a 91 Si hatch. He ordered a front clip from a JDM XSi integra. It also has the 15/16 master cylinder, only it will bolt directly up to the civics booster.
weird huh....
You might watn to cross reference part numbers or just do a visual comparison
Hondatypr636
04-26-2011 05:53 PM
EJ8CIVIC
07-13-2008 10:37 AM
underage
06-09-2005 06:33 PM
B HATCH
11
04-15-2004 05:07 PM
JeffS
03-07-2002 08:22 AM
Quick Reply: question on mc and brake booster swap question
