obd1 swap in an obd2 car
obd1 swap in an obd2 hatch
I have a 96 cx, with an 94 gsr swap. I would like to know if it is possible to convert it back to obd2. if it is, what would I need.
thanks in advance
thanks in advance
Re: obd1 swap in an obd2 hatch (v.i.gsr)
the easiest way to convert an OBD1 engine to work in an OBD2 car is by getting OBD2 B-series distributor, injectors, and alternator. And either run a JDM OBD2 ecu, or convert to OBD1. Avoid using a US OBD2 ecu because those ecu's look for the CKF sensor & 2nd 02 which your OBD1 engine does not use or have (CKF is integrated on the oil pump on US OBD2 engines).
or you can do it the semi hard way....
by repinning your distributor plugs to OBD1 dizzy , alternator, and injector plugs. Again, use a JDM OBD2 ecu or convert to obd1.
