Cable B16A in 91 Integra, Quick question!
Old Nov 18, 2004 | 07:30 PM
zeleftikam's Avatar
Default Cable B16A in 91 Integra, Quick question!
Hello friends,
I'm going to attempt to put a cable-trans B16A in a 91 Integra LS, my question is:
Can I use the stock B18B ECU with the B16A? I know it won't have VTEC but I need to get the car up and running so I have transportation (the B16B is blowed up...). Will it fire up and run on the B18B ECU?
Will the cable-trans B16A distributor be compatible with the B18B ECU and run fairly well?
Thanks in advance for any answers or advice to get me running,
zeleftikam
Old Nov 18, 2004 | 07:42 PM
zeleftikam's Avatar
Default Re: Cable B16A in 91 Integra, Quick question! (zeleftikam)
Also, will my stock Integra wiring harness work with the B16?
Thx...
Old Nov 19, 2004 | 05:42 AM
91civicDXdude's Avatar
it should bolt right in. you can use the PR4 ECU, but i woudlnt recommend it for any length of time and it will rob you of a lot of horsepower.
Old Nov 19, 2004 | 01:54 PM
zeleftikam's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">it should bolt right in. you can use the PR4 ECU, but i woudlnt recommend it for any length of time and it will rob you of a lot of horsepower.</TD></TR></TABLE>
Thanks!!!
dcsports
Feb 2, 2005 07:10 PM
dc ac king
Sep 26, 2003 10:13 AM
hahahahhah
22
Jan 14, 2003 06:21 AM
WuShu
May 14, 2001 03:19 PM
