ZC head on a Z6 block??
Alright, I tried searches, but I suck at knowing what to write to find what I need. I was wondering a few thigs... First, will a ZC head bolt on to a Z6 block. Second, are ZC pistons higher compression than Z6 pistons, and will they fit? Thanks for the help!
Re: ZC head on a Z6 block?? (SleepinT-REX)
an single cam zc head will fit but not the dohc as far as the pistons the pr7 pistons have a much higher compression than the p28 or whatever they are hope this helps
Re: (bluebird)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebird »</TD></TR><TR><TD CLASS="quote">What advantage are you trying to gain from using the non vtec head?</TD></TR></TABLE>
Exactly. Even though it is a bigger head, the vtec one has yet even better design.
Re: (fast88std)
I was wondering about the dohc head, but since that doesn't fit, I'll just stick with the z6 head. I am turbo'in the engine, so I wanted a little higher compression, but still able to be boosted.
CRXguy_88
27
02-28-2010 10:21 PM
