just install walbro 255lp HP
i have a H22 swap into my eg hatch... the problem is that with this fuel pump, when i first start my car the RPM sits at 1000 - 1200 rpm and then a minute later it rise to the 1500 rpm... why does this happen... does anyone has the same problem???
Re: just install walbro 255lp HP (yangja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangja »</TD></TR><TR><TD CLASS="quote">i have a H22 swap into my eg hatch... the problem is that with this fuel pump, when i first start my car the RPM sits at 1000 - 1200 rpm and then a minute later it rise to the 1500 rpm... why does this happen... does anyone has the same problem???</TD></TR></TABLE>
1k to 1.2k then jump to 1.5k rpm then what...after warm up how is the idle?
Re: just install walbro 255lp HP (yeegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr »</TD></TR><TR><TD CLASS="quote">
1k to 1.2k then jump to 1.5k rpm then what...after warm up how is the idle? </TD></TR></TABLE>
the idles is clean... it doesn't jerk back and fourth... it doesn't jump to up the rpm it slowly climbs up there... it only does it when i start it in the cold morning start... after when it is warmed up it starts fine and normal... i don't know if i'm losing fuel pressure or what the heck is going on.... what do u guys think???
Re: (THEUSED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED »</TD></TR><TR><TD CLASS="quote">Maybe its because your engine is warming up.</TD></TR></TABLE>
But doesn't it should just jump to 1500 when starting up.....
Re: (yangja)
its just the beast. i have 2 h22 that do that. for a while i coudlnt figure it out. i think its beacause there is a little leak on one of the gaskets. they are paper and tey do get old. but once it warms up its fine. try bleeding your coolent line and make sure your coolent level and mixture is right
Re: (H23vtecEG)
i guess i was lucky the swap i did didnt do that it idled normal, then again i sent my harness to hassport to have it wired, my brothers ek h22swap idles fine too but he also sent his wiring to hassport maybe wiriing? hope you get it figured out becuase it can be annoying, sorry i can't be of help...
for the lude swap
for the lude swap
Re: (H23vtecEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23vtecEG »</TD></TR><TR><TD CLASS="quote">its just the beast. i have 2 h22 that do that. for a while i coudlnt figure it out. i think its beacause there is a little leak on one of the gaskets. they are paper and tey do get old. but once it warms up its fine. try bleeding your coolent line and make sure your coolent level and mixture is right</TD></TR></TABLE>
i guess i can check on that... this problem didn't start until i upgraded my fuel pump... i guess i'll check there too, again... thanks for the info...
