Need AC belt Help!!
Need AC belt Help!!
Swapped a gsr into my eg. I want to retain my ac, so I bout the crv ac brackat to bolt up to my condenser, and the block. I went to use my stock d series ac belt and it is too loose. What belt should I use?
Search is down.
Search is down.
Re: Need AC belt Help!! (Touch)
put your stock belt on, tighten it up all the way, then estimate how much slack you have. there are 25.4mm's in an inch. roughly subtract how many mm's of slack you have from the length of your stock belt.
then go to the store and get a couple belts that are around that size. try em out until one fits, then clean the rest of them up and return em.
