HELP WITH B16 SWAP!
Old Oct 20, 2005 | 08:39 PM
Dr_Suess's Avatar
Default HELP WITH B16 SWAP!
i just put a b16a2 into my 95 civic coupe.... i used the stcok harness and ecu
...now when i went to start the motor up it starts but starts reving up to 3-4 grand and goes back down...up and down up and down...i thought timing was off but i reset it and it is dead on now....i replaced the tps sensor thinking maybe that was it...still same problem...im lost right now on what it is..im pretty sure its a sensor or a harness/ecu problem but i dunno what im looken for anymore...please give me some ideas on what it might be
Old Oct 20, 2005 | 08:42 PM
littleredcivic's Avatar
Default Re: HELP WITH B16 SWAP! (95_civic_eg)
sounds like idle air controller is defective or not recieving the correct signal. what ecu did you use?
Old Oct 20, 2005 | 08:44 PM
ekcivic9's Avatar
vaccum leak somewhere?
Old Oct 20, 2005 | 08:53 PM
Dr_Suess's Avatar
i have a p28 chipped and a p28 stock both do the same thing
i used the iac off my d16z6...worked fine on that and bolted right up
Old Oct 20, 2005 | 08:55 PM
Dr_Suess's Avatar
the only vacuum thats is not plugged is the pvc valve dont have one on it right now but even when i plug that vacuum same problem
Old Oct 20, 2005 | 09:15 PM
Dr_Suess's Avatar
bump
Old Oct 21, 2005 | 09:24 AM
CRXJIM's Avatar
It sounds like it is definatley a vacuum leak. Look at all your vacuum lines make sure none of them are punctured or unplugged. That is the only thing that I can think of. That is what usally indicates up and down reving. The other thing it could be is your throttle cable make sure it is adjusted right or no pinched.
Old Oct 21, 2005 | 09:52 AM
Dr_Suess's Avatar
Default Re: HELP WITH B16 SWAP! (CRXJIM)
bump
Old Oct 21, 2005 | 12:07 PM
Dr_Suess's Avatar
bump bump
Old Oct 21, 2005 | 10:19 PM
Dr_Suess's Avatar
bump
tibbits_b16
12
Feb 6, 2009 11:46 AM
joelmatt89
Feb 4, 2009 06:27 PM
93 EG
Feb 10, 2007 01:37 PM
JDM_SOHC
Apr 29, 2005 11:15 AM
SiLeo20
Apr 13, 2005 06:34 PM
