LS/VTEC help. please help
Old Oct 11, 2005 | 05:25 PM
hondaguyexsi's Avatar
Default LS/VTEC help. please help
im starting my planning on a ls/vtec. should i use the GSR block girdle consisting of # main caps in middle, bolts, windage, oil pan and oil pickup. also i know thw vtec oil pump is good but what about the water pump. im lookin for ideas so let me know whats the proper way to do this for a reliable engine.
Modified by hondaguyexsi at 11:36 PM 10/11/2005
Old Oct 12, 2005 | 03:27 PM
unknown0001's Avatar
Default Re: LS/VTEC help. please help (hondaguyexsi)
Get the Golden eagle LS/Vtec kit with dowl pins and head gasket. Get your compression figured out that you want and upgrade the rods with ARP rod bolts.
Search, this has been covered many times before.
Old Oct 12, 2005 | 03:57 PM
Default Re: LS/VTEC help. please help (Mr.RHTuner)
i know this has been covered but i dont see anything about using the gsr block girdle. i read the scc article about the ls/vtec and it mentioned it but is it necessary.
Old Oct 12, 2005 | 05:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyexsi &raquo;</TD></TR><TR><TD CLASS="quote">i know this has been covered but i dont see anything about using the gsr block girdle. i read the scc article about the ls/vtec and it mentioned it but is it necessary.</TD></TR></TABLE>
no it's not...it does the same thing as the b18a block girdle. I wouldn't worry about that much if at all.
Holderb20
Nov 15, 2006 08:12 PM
D-meet07
Sep 14, 2005 02:56 AM
testingcheck
Aug 14, 2005 10:50 AM
xwinterhalox
Feb 17, 2005 05:06 PM
Speed_Dreams
Jul 27, 2003 01:48 PM
