HELP! What ECU for a '99 B18B1 ???
What ECU should be used in a '93 si hatch. Motor is '99 B18B1, tranny is hydro S80 (i think?) Kid says it has a P05 ECU, is that good?
Re: HELP! What ECU for a '99 B18B1 ??? (ek99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99 »</TD></TR><TR><TD CLASS="quote">You need a p75 integra ls ecu(94-95) or pr4 integra ls(92-93). po5 is cx and it will run lean.</TD></TR></TABLE>
An update to this reply...
You can use any 92-95 PR4, P74, and P75 ecu ....which are all LS ecu's.
Or
You can use a P06 (92-95 DX) ecu that's been reprogrammed to LS spec. A P05 is capable of being reprogrammed to LS spec too, but in stock form, it will run lean and only be looking for a single-wire 02 sensor instead of a 4-wire 02 sensor which you should be using for your swap.
Or
