H22 crank sensor code cant get rid of
Old Oct 28, 2005 | 06:48 AM
nx h22's Avatar
Default H22 crank sensor code cant get rid of
I have tried everything changed the distributor checked wiring thought it might be my balancing shaft belt not being on so i put it on this code will not go away help me out it is a 92 eg h22swap
Old Oct 28, 2005 | 06:54 AM
nx h22's Avatar
Default Re: H22 crank sensor code cant get rid of (BoostedOrange)
the code is 9 cyp sensore
Old Oct 28, 2005 | 08:10 AM
Rudelude22's Avatar
did you pull the code or have you taken it to some1...cuz when you pull the code it just gives you a general idea, take it some1 spend the 60$ to have them put it on there 10k machine to pin point. or change out the sensor..
Old Oct 28, 2005 | 10:20 AM
coquitlamEG's Avatar
Default Re: (Rudelude22)
Just out of curiosity, have you tried reseting your ecu by unplugging the battery for 30 seconds? I'm sure you already know this, but the ecu will hold a code until it gets reset, even if the problem has been fixed.
Old Oct 28, 2005 | 11:36 AM
prelittlelude's Avatar
Default Re: (coquitlamEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coquitlamEG &raquo;</TD></TR><TR><TD CLASS="quote">Just out of curiosity, have you tried reseting your ecu by unplugging the battery for 30 seconds? I'm sure you already know this, but the ecu will hold a code until it gets reset, even if the problem has been fixed.</TD></TR></TABLE>
bingo! also you can phase out the sensor down there as long as you rewire it the right way.. make sure to clear that code.
Old Oct 31, 2005 | 08:55 AM
nx h22's Avatar
i have cleared the computer after every change i have done if there is a way to buy pass it let me know and is the sensor in the distributor right cause im not sure
Old Oct 31, 2005 | 11:05 AM
Sam1am26's Avatar
H22A, a1, a4? ECU? Dizzy? Need more info...
Old Oct 31, 2005 | 12:58 PM
Dragline's Avatar
Default Re: H22 crank sensor code cant get rid of (Sam1am26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote">H22A, a1, a4? ECU? Dizzy? Need more info...</TD></TR></TABLE>
This info would help
Old Oct 31, 2005 | 01:32 PM
nx h22's Avatar
Default Re: H22 crank sensor code cant get rid of (nx h22)
its an h22a with a p28 hondata s100 it never did it until i rebuilt the motor and ever since then it has done it
Old Oct 31, 2005 | 06:59 PM
Turbogixxer's Avatar
Code 9 can mean a few things. I really do not see the actual sensor fail (if you do not mess with it). I have seen a lot of bearing problems with internal coil (you said it was a h22a, JDM, so it will be internal). The bearing will create slack and throw the reading off to the ecu, thus your CEL.
Start the dizzy for red dust or bearing failure.
Old Nov 1, 2005 | 06:28 AM
nx h22's Avatar
it is an external coil
Old Nov 2, 2005 | 05:04 PM
dropcivic's Avatar
Bump, i am having the same problem too expect our dist is jdm one, internal coil. And yes, it is a brand new dist.
Old Nov 4, 2005 | 02:00 PM
dropcivic's Avatar
Default Re: (dropcivic)
Nobody? I checked my wiring and i know i didn't switch any wires for the CYP sensor. The wiring diagrams showed nothing about changing them.
superslowcrx91
Sep 30, 2013 12:54 PM
Sephrin
Nov 10, 2009 04:24 PM
ilikejesus
Jul 2, 2007 06:10 PM
T--Rex
Jul 10, 2004 02:15 PM
1EK1EG
Jun 13, 2003 05:13 PM
