Motor swap time.....
i have a 97 civic and im putting in a obd0 LS motor...i having a problem with trying to firgure out the crank sensor thing...i going to run a obd2 dizzy and ecu...my question is can i use a 96+ LS oil pump, crank sensor and crank gear??? i know i have to change out my rear mount to 99-00 si and my ac mount to b20..is it true that i can use my stock driver????
just to let you guys know..the only reason im going to run this obd0 motor is cause it has been rebuilt....
