What mounts would you use to swap ls vtec in a del sol???
Well i just sold my crx!!!! and i picked up an automatic del sol for 700$ with a mint body and i wanna swap my ls vtec in there....i know i gotta convert it to stick...but i dont know what mounts to use?? or what shift linkage ...i searched yesterday but it wouldnt let me search on here .....but i was on yahoo for like 2 hours...can someone help me out
Re: What mounts would you use to swap ls vtec in a del sol??? (hotimportcrx)
Any b-series mount will work and as for the shift linkage you'll need a Del Sol VTEC one. As far as the auto to manual that's some thing that someone will have to answer.
Re: What mounts would you use to swap ls vtec in a del sol??? (Lee_Delso)
ok for the shift linkage does it have to be a b series shift linkage....or it can be the single cam vtec del sol shift linkage?
Re: What mounts would you use to swap ls vtec in a del sol??? (RS93DA)
but i am still confused as to what mounts to use.....because the del sol is automatic...so i can get any 94-00 integra mounts and my ls will bolt right up???? because i think the auto mount bracket is different
do you think this one is the right one??? http://hasport.com/catalog/pro...5fb19
maybe someone else can confirm this but i cant remember right now, does the d series tranny mount bolt to the b series tranny? if it does then that is the correct mount you need but i cant remember, check for the integra one and see if the part # is the same
yes the d series trans mount can bolt to the b series i just did a LS swap into my hatch and i used that mount.
auto to manual you are goin to need...
1. clutch kit
2. flywheel
3. manual trans
4. slave cylinder and clutch master cylinder
5. Clutch pedal
6. dont forget to buy the pressure plate and flywheel bolts (14bolts-6pp-8fly)
there may be more i wrote up a thread a few days ago about ls swap going auto to manual.
1. clutch kit
2. flywheel
3. manual trans
5. Clutch pedal
Re: What mounts would you use to swap ls vtec in a del sol??? (92civichatch1)
heres my thread...https://honda-tech.com/zerothread?id=1417060
Re: (ZzZCivicZzZ)
someone told me you can use:
94-00 Driver Side Integra MOunt and Bracket
Stock D Series Rear Mount
94-00 Integra Rear Bracket
Stock D Series Tranny Mount
ejv8s10
09-03-2014 11:52 AM
skiracer8148
03-17-2007 05:09 PM
spike
07-30-2004 10:45 AM
