HELP juss did a swap.having idle or some shit problems and vtec aint kickin it
HELP juss did a swap.having idle or some **** problems and vtec aint kickin it
i juss did a swap. its a single vtec motor that was in a EG and i put a jdm b16A block with a US 95 gsr head and manifold. the car turns on and runs and everythang but the only the is
1st problem is the idle most of the time gets stuck on 1500rpm and then the motor seems to start continuously hopin or some **** as if its not gettin enoff fuel or the idil seems to b stuck on 1500rpm . i adjusted the idle n everythang too.
2nd problem i dont believe VTEC is kickin i KNOW it aint.
IF you know what it could be or anyone please help thanx
Re: HELP juss did a swap.having idle or some **** problems and vtec aint kickin it (lsvtec4o8)
check and see if your throttle cable is too tight also as far as the vtec goes could be a number of things what codes is it throwing, what ecu are you running, do you have butterfly on intake manifold hooked up or not
