b series into 96 ek
b series into 96 ek
are these the right part numbers and only mounts i will need to buy?
Rear Tranny mount from the 99-00 Si: 50827-S04-N10
Driver side mount bracket from the 99-00 Si: 11910-P30-000
just need to double check to make sure im getting the right parts.
Re: b series into 96 ek (akteamster)
You can use your stock motor mounts. The only thing that you need to change is the REAR crossmember mount. You'll need one from a 99-2000 Si.
JDM99DC2
04-12-2005 06:15 PM
