need help on axles
Old Oct 16, 2005 | 07:44 AM
silverxcivic's Avatar
Default need help on axles
i have an ek dx and i was wondering if i can put b series axles but i only have a single cam motor
Old Oct 22, 2005 | 07:44 PM
lsvtec4o8's Avatar
Default Re: need help on axles (silverxcivic)
you wont b able to bcuz both the DOHC axles bout the same size. And the single cams one is long then the other. so they both have different sizes.
Old Oct 22, 2005 | 07:53 PM
lsvtec4o8's Avatar
now if you can help me how the hell do u post up questions? cuz i juss did a swap. its a single vtec motor that was in a EG and i put a jdm b16A block with a US 95 gsr head and manifold. the car turns on and runs and everythang but the only the is
1st problem is the idle most of the time gets stuck on 1500rpm and then the motor seems to start continuously hopin or some **** as if its not gettin enoff fuel or the idil seems to b stuck on 1500rpm . i adjusted the idle n everythang too.
2nd problem i dont believe VTEC is kickin i KNOW it aint.
IF you know what it could be or anyone please help thanx
EusebioSam19
Sep 4, 2012 07:34 AM
builtB20turbo
Feb 16, 2011 07:29 AM
F22PwrdS2k
Dec 21, 2006 04:12 PM
DRKSol
Dec 14, 2003 10:04 AM
95CivEX
Sep 24, 2002 05:03 PM
