engine bogging, starting, and hesitation problems b16a
Old Oct 17, 2005 | 07:12 AM
xkagax's Avatar
Default engine bogging, starting, and hesitation problems b16a
So when I start my car when its cold, it likes to sometimes stall. When it doesn't stall or after you start it back up, the engine kinda bogs, or seems like its choking when you give it gas, it just kinda coughs and won't rev. It'll drive, it's just hard for a while since it won't really accelerate untill you pretty much floor it. Now once it warms up its fine, it's only when the motor is completely cold and you just start it. I've done the following:
-new fuel filter
-seam foam through the brake booster
-new distributor
-new plugs, and wires
it's a jdm b16a in a 97 hatch. I've read quite a bit and found that it could be my throttle body needs cleaned, which I'm doing asap (I need a new gasket first), or possible my main relay has gone bad... if anyone can give me some help or other things to check, please let me know. Thanks in advance!!!
Old Oct 17, 2005 | 08:25 PM
xkagax's Avatar
Default Re: engine bogging, starting, and hesitation problems b16a (xkagax)
up
Benz_05TSX
Jan 31, 2015 12:18 PM
Z0831xiz
Aug 26, 2013 03:54 PM
xkagax
Oct 17, 2005 07:12 AM
B16aEGx2
Apr 15, 2005 05:22 PM
