quick ?
Old Oct 31, 2005 | 03:07 PM
dasistheone's Avatar
Default quick ?
To swap an obd2 engine what wiring will i need. i have an eg, search is down
Old Nov 2, 2005 | 10:05 AM
jdmcars.com's Avatar
Default Re: quick ? (dasistheone)
You will need a wiring conversion harness if you are planning on using the OBD2 parts, such as the ECU. You will a to know which OBD2 ECU if that is your plans, either OBD2a or OBD2b.
Really need more details of what you are trying to do to better answer.
Old Nov 2, 2005 | 01:56 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dasistheone &raquo;</TD></TR><TR><TD CLASS="quote">To swap an obd2 engine what wiring will i need. i have an eg, search is down </TD></TR></TABLE>
depends..
help us help you.
Old Nov 2, 2005 | 09:15 PM
Default Re: quick ?
I was lookin at the jdm type r motor b18c5 but on hmotoronline it says 98+ what wiring would i need to put this in my eg.. will this engine run good with odb1 p72
amish_assassin88
May 14, 2008 07:05 PM
EG TYPE-R
Apr 8, 2005 05:04 PM
mugenracer
Mar 3, 2005 05:19 PM
DannyNada
11
May 20, 2004 01:17 PM
