obd2 to obd1 distributor wiring help
Hey was up. I am putting a b16a into a 90 civic si. I have the motor in and using the si harness. Only thing missing is the distributor. I have a obd-2 GSR distributor. I heard you can use this How do I wire it up. I have both halves to the clip so what do I do? I did a little reading and I am guessing I can use a jumper harness and go obd-1 and run a p-28 and use this distributor but I dont know how to make it obd-1. I seen a diagram from poison on how to go obd2 to obd1 but that is using an obd1 engine harness.. i am using an obd0 harness. Someone help?
Re: obd2 to obd1 distributor wiring help (redlinerz)
just match up the colors of the wires...everything should be the same....but you have to use an OBD1 computer if you are going to use the OBD1 or 2 distributor...the OBD0 ECU will not work with the OBD1 or 2 distributor.....
Technical Hero
Re: (Ch3mik)
OBD0
1Orange
2White
3Orange/Blue
4White/Blue
5Blue/Green
6Blue/Yellow
7Large White
8Black/Yellow
9Blue
OBD2
1Dark Blue
2White
3Green
4Red
5Yellow
6Black
7Yellow/Green
8Black/Yellow
9Blue
1CYPP
2CYPG
3TDCP
4TDCG
5CKPP
6CKPG
7ICM
8IGN OUTPUT
9TACH OUTPUT
1Orange
2White
3Orange/Blue
4White/Blue
5Blue/Green
6Blue/Yellow
7Large White
8Black/Yellow
9Blue
OBD2
1Dark Blue
2White
3Green
4Red
5Yellow
6Black
7Yellow/Green
8Black/Yellow
9Blue
1CYPP
2CYPG
3TDCP
4TDCG
5CKPP
6CKPG
7ICM
8IGN OUTPUT
9TACH OUTPUT
jdmjin
11-26-2017 08:59 PM
Patrickchampagne2006
03-21-2007 02:35 PM
DIYMIKE
02-23-2007 09:06 PM
Adam West
05-08-2006 03:47 AM
