Which chassis/engine harness should I use? H22A4>>1996 LS
As stated, I got a 96 LS I picked up to house the nasty H22. The current harness is kinda hacked up so Im thinking that it will be way easier to just throw in a whole new harness rather than mess with the wiring abortion that is in there now.
So which one should I use? I found a cheap 1996 GSR harness that is cheap, should I go with that since its got the vtec wired in already? or should I go for another LS harness? Im guessing that they are the same minus the vtec....
TIA
TIA
Re: Which chassis/engine harness should I use? H22A4>>1996 LS (NXLude)
The guy who did my H22 swap re-used the LS harness in mine and added a few clips (VTEC, knock sensor etc) I would imagine locating a GSR one would be best, all that stuff is already there.
Modified by simon98h22 at 8:20 PM 10/30/2005
