B16A...to...B18C
Old Oct 27, 2005 | 05:17 PM
P@@RB@Y's Avatar
Default B16A...to...B18C
I have a 94' Si with a B16A2 swap.What all do i need to swap a B18C block in?Axles, wiring etc...
Old Oct 29, 2005 | 03:57 AM
P@@RB@Y's Avatar
Default Re: B16A...to...B18C (P@@RB@Y)
Anyone?
Ive searched but didnt come up with if the axles, wiring etc.. will work with it.
Old Oct 29, 2005 | 10:52 AM
x916's Avatar
i have a gsr shortblock forsale
Old Oct 29, 2005 | 01:46 PM
P@@RB@Y's Avatar
Default Re: B16A...to...B18C (x916)
Thanks for the info.
Old Oct 29, 2005 | 01:50 PM
EGDC2CIVIC's Avatar
all you need to do is wire the iab's if your gonna use the p72 ecu
Old Oct 29, 2005 | 01:58 PM
P@@RB@Y's Avatar
Default Re: B16A...to...B18C (EGDC2CIVIC)
So the wiring harness needs a little changing and the B18C block and a different ECU.Everything else will work?Axles, shift linkage, mounts etc....
Old Oct 29, 2005 | 04:10 PM
EGDC2CIVIC's Avatar
yes the axles, shift linkage, and mounts will be the same. the wiring is changing 1 wire at the ecu if you use the gsr engine harness. if your using the b16's harness its a little more work, and theres plenty of archived threads on how to do that
Old Oct 29, 2005 | 04:46 PM
P@@RB@Y's Avatar
Will the B16A tranny gears be to short for a dailey driver?
Old Oct 29, 2005 | 05:07 PM
EGDC2CIVIC's Avatar
no i dont think they would, my brother has a b16 tranny and i have a gsr tranny and at 80 mph in 5th gear he is at 3500 rpm's and im at 3100
Old Oct 30, 2005 | 01:51 AM
tianporn's Avatar
Would you need the drivers side engine mount for a B18c?
Im thinking of converting my JDM EG9 SiR from factory B16a to B18c and ive been told i have to replace my passengers side (since im RHD) engine mount for a B18c item
Old Oct 30, 2005 | 08:23 AM
SlowB16si's Avatar
Im also planing on doing this, I have a 2000 si witht he stock b16 and just want to put in a GSR block. It has a obd2b-obd1 conversion harness and running off a p28ecu. What wall is needed for this swap?
Old Nov 1, 2005 | 09:45 PM
tianporn's Avatar
Default Re: B16A...to...B18C (tianporn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tianporn &raquo;</TD></TR><TR><TD CLASS="quote">Would you need the drivers side engine mount for a B18c?
Im thinking of converting my JDM EG9 SiR from factory B16a to B18c and ive been told i have to replace my passengers side (since im RHD) engine mount for a B18c item</TD></TR></TABLE>
Bump
Old Nov 2, 2005 | 07:05 AM
HONDA RR's Avatar
I think the only thing that might be different is the wiring and everything else should be the same. Why are you going to put a b18c block with a b16 head it will give you low compression?
Old Nov 2, 2005 | 01:05 PM
P@@RB@Y's Avatar
Default Re: B16A...to...B18C (HONDA RR)
Torque
Old Nov 2, 2005 | 09:53 PM
tianporn's Avatar
Does B18c and B16a use same mounts for EG chassis?
Old Nov 2, 2005 | 10:29 PM
WhiteNess's Avatar
This is about as straightforward of a swap as there is. A GSR with a b16 tranny is a quick racer and a good daily driver. Everything is the same just switch it over. If you use the same wiring harness thats on the b16 your going to need to wire the secondary butterflys, but if you get a gsr harness and ecu then its all plug and play. The mounts are interchangable as well....either use 2000 si or integra mounts....the part that bolts to the block is what determines which bushing to use.
Bloody Hatch
Jun 28, 2012 01:39 AM
xft
12
Oct 17, 2008 05:06 AM
jedi_first_degree
Aug 21, 2005 05:30 PM
JDM CTR EK
Jul 15, 2003 12:12 PM
